MICSTO error Could not implement all needed function hooks.
Hi there,
This is an unknown error for me. I have no idea what causing it, from where did it came from and why. All I know that it appeared suddenly on my desktop. Anyone can recognize this error? What is causing it?
Thank you!
MICSTO
OK
Answered By 590495 points N/A #190155
That error appeared because you are using MICSTO. If you did not start MICSTO manually when the message appeared then it probably starts with Windows. First, try restarting your computer and then start the application again. See if it works normally. If not, reinstalling it might help. Uninstall MICSTO, restart your computer, and then install it back.
Though it is not actually necessary to restart the computer, it is just a good way of refreshing the system after removing a program because there are times even if the program doesn’t prompt you for a restart, behind that it still updated something on the system because of its removal. That’s why rebooting the system after uninstalling is still good.
In case you are using an outdated or old version, you can download the latest from MICSTO M!Table and M!Image. Though it says it supports all Microsoft Windows versions x86, if you encounter a problem, try running it as administrator. Right-click on the program icon and select Properties. Select Compatibility tab, under Privilege Level section check “Run this program as an administrator”. Click OK and run the program again.
If the problem continues, try downloading the patch from M!Table and M!Image Patches.
