Middle level Flash CS4 meanings and proper usage of the objects
70 points
Posted on - 04/20/2015
I would like to know deeper information in Flash CS4. What are layers in Flash? What are the proper usage of it in Flash projects? What do you mean by Stage in Flash? What is the use of Transform in Modify options? What is the use and name of the icon with a chain like appearance? What are the buttons available in Layer window? What is the proper use of the small squares below layer? What do you mean by timeline? How is it created? What are the attributes include in Layer Properties box?
Thank you!
