Melany F
Posted on - 10/13/2011
My problem is an error message I’m getting while trying to run Midisport Uno Drivers. Everything else seems to be working fine on my Windows 7 except for this one. The error I’m getting is this: “Microsoft Visual C + + 2005 Redistributable, There is not enough space on the disk.”
Error:
I am open for any suggestions so if you can help please leave a post.
Midisport Uno Drivers start up
Check your hard drive if there is still sufficient free space for the program to run.
If there is no problem with the disk’s free space, try updating Microsoft Visual C++ 2005 Redistributable.
It might be encountering some problems with the program that’s why it misreported the drive’s available space.
Try doing a disk check on drive C to check its file structure for errors.
Right click on drive C and then select Properties.
Click Tools.
Click Check Now button.
Check Automatically fix file system errors and then click Start.
Try running the program again after the disk check.
If the same error is reported, uninstall Midisport Uno Drivers and then install it back again.
Launch it afterwards.
