Migrate from .pst to .msg using Microsoft Outlook 2010?
Is there a way to import .pst files and then exporting as .msg files in MS Outlook 2010? Also, is there some open source converter for this specific purpose?
First of all I would like to answer your second question. Yes, there is an open source converter for this purpose. It is OLBreak. Download the software and convert the PST file to MSG file and import in MS Outlook 2010.
I think your problem has been solved.
Thanks
Hathy
If you want to migrate .pst files to the Linux platform, Thunderbird will recognize them, and also Thunderbird should have the option to open those files and save them under a different extension.
