Mikrotik Router Load Balancing Issue
I have one Mikrotik router in my office for bandwidth control.  Model of the Mikrotik router is RB450G. I want to use this router for load balancing.  Just like,   1 Internet connection will be for browsing and another Internet connection will be for download.
Or,
Even connected users will be connected to one Internet and Odd connected user will be connected to another Internet.  If it is possible, please let me know?
Thank You
Answered By 0 points N/A #118872
I guess this is a big issue of connecting one PC to another.  But don't worrry, I will try my way on how to solve the problem.  In this situation, if you want to connect the PC with load balance, you need to have a SWITCH HUB.  This way, it delivers the connection to a maximum equal connection individually.
This screen shot will tell you how it works.
The LOAD BALANCER of a router will mainly be distributed by Switch Hub for MULTIPLE USER.
You can also activate the computer 1 , 2 and 3 by:
GO TO the "CONTROL PANEL+NETWORK AND INTERNET+NETWORK AND SHARING CENTER"
or you can just right click the " NETWORK iNTERNET ACCESS"  located below the Desktop.
ClicK the "Change Advance Sharing Settings". Can be seen above with a red circle and arrow.
Read the content and you can now change the setting by choosing specific option you want to change for SHARING.
Upon activating what you have shared, IT will automatically share  DOCUMENTS to another computer.
To OPEN the file and Sharing Documents, you can see this in:
  • Go to Start Menu
  • Click the COMPUTER.
  • Locate and CLICK "Network"
  • In NETWORK, you will find the PC that mainly connected to your documents.
  • You can now SHARE your documents to other PC.
I hope that this long solution will get you what you want.
