I am starting to learn computer graphics on my Samsung Mini Laptop. I installed Adobe suite CS5 on it and I mainly work with Illustrator and Photoshop. I have this problem with Photoshop such that when I try to save for web the window becomes larger than the screen size. I can’t see the save button nor the close button so I can only close the whole program from Task Manager. What can I do? I would also like to know the best laptop for graphic design as well as the best specs.
Thank in advance.
Mini Laptop screen size is smaller than Window size
Sorry to say that I think your mini laptop is not suitable for working High graphics work. So you are facing this problem.
There’s the configurations which is needed listed below.
CS5 and CS6 needs a multicore processor which is 2 GHz or faster.
You should use as much ram as you can fit it on your laptop in Windows 64 bit. If you use more ram Photoshop can process the photos more quickly.
Use a fast and also a large hard disk. You can also use Solid state disk (SSD).
You should keep your video adapter driver updated.
Use more external graphics card (1/2 GB) with 1 GB internal. This will help you much better.
You can use a desktop computer with the configuration stated above. Here some laptop names which can be useful for these purposes.
1. HP Envy 4,
2. HP Envy TouchSmart 15,
3. HP spectre XT TouchSmart,
4. Dell XPS 15,
5. Apple Macbook Pro,
6. Lenovo IdealPad Y510p,
7. Asus G750JW-DB71 17.3-inch Laptop.
Hope this will help you.
