I have been using mini PDF to PowerPoint converter for converting my PDF files to ppt presentations. The program now crashes since I upgraded my OS. I am now on a Windows 8 OS from a Windows XP 64 bit SP2 system. Any ideas how I can make the program work?
Mini PDF to PowerPoint converter crashes on Windows 8
HI Eleni,
Yet there are many programs which are not compatible with windows 8 Operating System. You should try changing the Compatibility of program. Follow below step to make it Run.
1. Select the program by mouse click
2. Click the secondary button of the mouse or touch ( it will open tabs like – open , delete, properties , etc..)
3. Click on the " Troubleshoot Compatibility"
4. Wait for program to find the Issue
Or
1. Open the Properties of program ( by doing step 2 from above )
2. Click on CompatibilityÂ
3. Click on " Run this program in compatibility Mode For " check box
4. Choose the OS version which is Compatible
This Will Work fine, If these above step does not work, you need to wait for the Update of the Program.
Hi Eleni,
I see that you have finally decided to upgrade your Windows OS from XP to Windows 8.
There are certain applications on XP are no longer running on upgraded versions of Windows OS like Vista, 7, and 8.
To save you the trouble, you can just download a PDF to PowerPoint file converter which is compatible with Windows 8.
I recommend to use this software called Wondershare PDF converter.
You can download it here or for more information you can visit to their website here.
