Mini Secure Pro Wireless Keyboard 128-bit AES Encryptioner a descriptive
When I am typing a password or bank information , Can it automatically encrypt those? Is there audio media control? What is the USB port version and how many ports are there? Is Pro Wireless Keyboard 128-bit AES Encryption compatible on MAC OS? Is there Anti-Ghosting n-key rollover and charging cable? Has it sculpted keytops?
Answered By 0 points N/A #200332
The Mini Secure Pro Wireless Keyboard comes with 126-bit AES Encryption, which is an encryption procedure that is thought to be the strongest type of encryption available.  Every keystroke of the keyboard is transmitted with this type of encryption, so it avoids anyone from maliciously capturing  your most important information, like bank details or any password.
The keyboard has Quiet click buttons, which provides solid feedback while striking the keystrokes on the keyboard, but without the mechanical noises that normal keyboards make.
Included on the keyboard, is 3 x USB 2.0 ports, for charging other devices (like mobile phones, tablets, cameras etc.) while the keyboard is in use.  The cable length is 6.5 feet (or 2 meters).
While other wireless keyboards may suffer from key combinations that are faulty or type extra letters that you haven’t typed (also known as ghosting), the Secure Pro keyboard has a superior circuitry which will eliminate this problem.
The Secure Pro comes with sculpted keytops, which is curved to fit your finger tips and keeps your fingers from slipping off the keys.
