Minimum number of rows and column
Asked By 7060 points N/A Posted on -
What is the figure of minimum number of rows and columns that a Microsoft Word 2003 table menu can have?
Best Answer by shuvo039
Answered By 0 points N/A #80076
When we need fixed column and row, then we make some fixed column and row.
Answered By 0 points N/A #80077
Hi Jagodish1,
My answer to your question is, I would say no minimum number as it will automatically generate number when you start using numbering in Microsoft Word 2003.
You may follow these steps to find out;
  • Go to Table menu, point and then click Table.
  • Click OK, then return to the dialog box.
  • Choose first cell in the top column.
  • In this, all categories should display all.
  • Click on the autoNumOut then OK.
  • Select and copy the field in the cell.
  • Choose the column and paste from the edit menu. As this will auto-generate number when doing numbering in Microsoft Word 2003.
Thanks
Answered By 0 points N/A #80079
I think it is like MS Word 2007. I have counted the number of columns and it is 63. The number of Rows are 32,767. Table menu has orientation.
  • Go to table menu.
  • Click on Insert. You will get your Insert Table. Here you will see Number of Columns field and Number of Rows. You must type the number of columns in the field. You may select 7. You must select the number of rows 600.
  • Then click on OK. You will see your Table on the page of document. You will feel the theme of your document and you can try to save your document with a file name.
