Minimum system requirements to install Matlab R2012a ?
Which are minimum system requirements to install Matlab R2012a with Simulink? And can I install the program with Windows Vista?
The system requirements for Matlab R2012a are the following:
To check on the new features for Matlab R2012a you may visit https://www.mathworks.com/products/matlab/whatsnew.html?nocookie=true
Mathlab R2012a is supported in Windows 32 bit or 64 bit OS and Windows Vista Service Pack 2. Technical support is also available for Windows Vista and currently, the product is supported based on its platform road map. I see no problem that your software will not run on Windows Vista since it is supported. If you have not updated the Vista service pack, do so now as it is the required product.
