MinuteMan Data Backup Suite 8.0
Hi all, I need a software similar to MinuteMan Data Backup Suite 8.0 that will have features for encryption and automatic backup. Please do the needful for suggesting a freely available software. Thanks, Athan Haas
I would recommend using the Genie Backup Manager which has 128- , 192- or 256-bit encryption. This is a more preferable back up system when compared to the Minute Data Backup Suite 8.0 which does not have certain vital features and cannot perform registry backups.
Hi Athan I say NovaBackup can do the trick you can download this free if you search hard enough you can easily back up all files including photos/music/documents and applications. It even comes with free online storage to back up your most critical files remotely. The software is simple to use even if its you first time users.
Notifications
