Mio Alpha was unable to connect to my phone via bluetooth
My Mio Alpha was unable to connect to my Samsung phone via Bluetooth. I have tried everything I can think of to get this to work.  Is this a common issue, user error, or both? I would appreciate any suggestions or help. I am not due for a new phone for another year so getting a new phone isn't an option right now. Thank you!
Answered By 0 points N/A #181366
  • First of all, verify whether the Bluetooth settings are properly turned on in both the devices and is properly detectable, by placing them close to each other.
  • Also check for any system or drive updates and install them if available.
  • Confirm the proper connection of the Bluetooth adapters used.
  • If all these strategies fail in solving the issue, try contacting for technical assistance.
Best regards!
