I have Miro software installed on MAC Pro 10.5.6. Previously I had a hard time installing the software on my machine. After a little struggle I managed to install it on my machine.
Now when I try to launch the software, it comes up with an error message
Miro Error
An unexpected error has occurred during execution Of the main script
ValueError: not allowed to raise maximum limit
I thought it could be due to bad installation, so uninstalled the software and then reinstalled it back again. But I see the error still exists.
If anyone has come across this error message please help.
Ronald01
5 points
Miro software throws error message on Mac
First, you have to check which version of operating system you are using. Is it registered or not? Try to update the previous or the best thing is to uninstall it and download the new and latest version from a good source and make sure that your system supports the latest version.
The other thing is, that there might be some corrupt files or some virus, which is resisting the running of your program, so try to scan your computer and repair the windows and other files. Do this in normal mode or the best thing is to do it from safe mode.
Download the latest FoF version 1.3.110, which also supports MAC and install it and follow the instructions and restart your system and try again. This will solve your problem. You can use this link to download the latest version of Frets on Fire.
I think you have 2 solutions and you can choose one of them as it is up to you
First ; you may need to download and install the latest version as it solved many errors like that you have so you can download the new version from this link http://www.getmiro.com/download/ and it will solve your problem and you will not face errors like you have like i said before
Second: you may have something that block Miro so you need to pass all the connections to Miro so you will find that interface of your Miro version is updated so i think this solution will be more helpful for you but like i said it's up to you
Hope these Solutions Help you
