Missing Administrative Tools in Start Menu
The issue I am facing is about the emptiness of the menu in case when I try to access the Administrative Tools in the Start Menu. Help me to find out the cause and the solution to restore them?
Restart Again your computer system, it will resume the settings again.
I have restarted many times, but no change.
I think it was deleted accidentally.
Now tell me what to do?
Should I reinstall the Windows Operating System or something else will resume this?
This can be issue with the shell folder path for the Administrative Tools folder that may be reset incorrectly or the Administrative Tools were deleted accidentally.
You need to upgrade your windows OS once because in case of upgradtion you don't need to reinstall all other software's except Windows Operating System.
Try it.
Ok Fahar,
I will do it tomorrow.
But let me know one thing is it will be not harmful for my computer to work in this situation till tomorrow?
Gorgeous it’s superb
I can’t imagine that there can be a solution for this with reinstallation.
Thanks a lot Fahar.
Thanks a lot.
I Found another solution for this issue but its long and sensitive.
Go to start menu and click the properties and then choose the start menu tab and then choose the customize and then add the icons whatever you want to add to the start menu.
Thanks,
Anilkumar.
