Missing Airplay option in the control center
I'm thinking of playing music from the iPhone to my home theater. I tried to use the airplay feature, but when I checked the control center I couldn't find it there. I am currently running iOS 7. Is this a settings issue or is it because I have an iPhone 4?
Answered By 0 points N/A #151744
To connect your iphone to a home theather, try following :
AUDIO ONLY
Try to connect your iphone via sing a 3.5-mm-to-RCA cable.
Another option is 3.5 mm audio cable into the iPhone's headphone jack and plug the other end into a 3.5 mm auxiliary input jack on the receiver
VIDEO AND AUDIO
Use a third-party docking station to output the video to three-cable RCA connection. If you have apple TV, it can log directly into a video service and It is the only streaming box that enabling connect to a home theater.
