I have a Windows 7 64-Bit as my Operating System and I have just installed Daemon Tools Lite 4.45.1.0236 Free License in my computer. After it completed the installation process, I could not find the file at all. It is not in the system tray and I could not find it anywhere. How could I find it where? It’s so erratic that the file is missing just right after it is being installed. I already have tried re-installing it for so many times but I still could not locate where the file goes. Could you help me?
Missing Files after installing Daemon Tools Lite
Have you tried checking the program in the control panel? Because the file may be on the system but you are not using the right procedure to locate it. Do the following:
Go to the control panel and check if the program is on the list of installed programs.
If it is there, you will need to go to start on your computer, and then in the search box type 'Daemon Tools' and then press enter on your keyboard.
The program should be on the list of programs, and therefore it will be listed when you search for it.
After you press enter, it should be opened.
-Clair Charles
Clair Charles,
I was able to find the file with your help. Followed the instructions that you gave. Thank you
