One user informs that from what he could see, the -mtune flag was not available for this type of processor in man GCC. He had to modify the construct options observation out all the lines.
I don't recognize if this is the right way to continue but was just a way for me to get results quick.""Missing header file ffmpeg/avcodec.h" and "Missing header file postproc/postprocess.h" "cc1: error: invalid option `tune=opteron”.
Need your help. Thanks.
Missing Header files – -mtune flag not available
Hi
Here is the solution of your problem you need to do the following tasks in order to solve your problem
First go to your backend and replace the software you are using the header files miss is due to the some files from the backend and due to this you need to replace your software and re-install this software first.
Do not upgrade this software otherwise this problem will not solve and will remains the same so just go and change the software by uninstalling this software and again install this software and your header file will again working and you will get this problem.
Hope this solution will get you out of this mess.
