Missing index dat file location in Windows 7
Hi Everyone,
What is the cause of this error "Missing index dat file location" in Windows 7?
Please help.
Thanks,
Elijah
Hi Everyone,
Please help.
Thanks,
Elijah
Hi Elijah,
"Index.dat" are hidden files located on your computer which contains all of your visited websites.
To fix it you can:
Hi Elijah,
index.dat file is a database file which comprises of important information pertaining to URLs, search queries and files that were recently accessed. The use of this file is to help quick retrieval of data that is used by the browser.
You can try the following paths to locate your index.dat file in case it was deleted by programs such as Red Button, CCleaner, Index.dat Suite etc.
C:Users
C:Users
Running the application again recreates the index.dat file.
Notifications
