harry jones
Posted on - 11/01/2011
I am having a problem with Twitter application when opening in iOS 5: I can't find the news feed. I just got my new iPhone 4S then I backed up my old iPhone 4. Afterwards, I synched my iPhone 4s with my backed up files through iTunes. Then when I tried to open the Twitter app, it says 'Private account tap to retry.' I can see everyone whom I follow but I can't view the usual news feed. Can someone please help me figure this out?
lee hung
75 points
Missing News Feed in iOS 5
Hallo Harry Jones,
It could have been a problem during the sync process that is causing you not to see the news feeds application on the twitter social network with new iphone 4S. I will suggest that you try syncing the files again and see if that will help solve the problem.
You can also just try connecting to twitter directly on the new iphone 4S with the twitter mobile credentials that you had created the account without syncing and see if you cam be able to see the news feeds that way. Or you can try syncing the iphone using a computer instead of using the old iphone.
Hope this helps.
__
Regards
Lee Hung
