wexler
Posted on - 02/22/2012
Hello experts.
I am getting the following error message on Adware. I don’t know how to solve this error. Please help. Thanks.
"The description for event id 0 from source lavasoft ad-aware service cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer. If the event originated on another computer,the display information had to be saved with the event. Following information was included with the event : "Only one instance of service process is allowed". Additional log :Log name – application;source – lavasoft ad-aware service;event id -0;level -error."
Missing or corrupted components causing error on AdAware
Hi
The problem you are facing is that your anti-virus that you are using is Adware is not working properly and you are receiving the error from the software while in running the problem is that you are virus has been not working because of the two options:
1. One option is that your anti-virus has been affected by any anti-virus that is why it is showing that your software component has not installed or corrupted so the solution is this you have to install the software again and this problem will solve.
2. Other option is that your software has not installed properly because the copy of the software you are using is might not good and some files are missing so therefore the solution is still the same install your software again but you should not install the same copy of the software bring the new copy of the software and then install that new copy it will solve your problem otherwise you will still getting the same problem. So try this one hope this solution will sort out and you will get rid of the problem.
That’s the Event Viewer you are accessing on your computer. You should not pay much attention to that because it is just part of the operating system that stores the logs of every program that runs on the computer. The error you see in the Event Viewer is just the result of the interaction of the operating system with the specific application.
If you like using Adaware antivirus, you should download the latest Adaware Free Antivirus. The latest version at the moment supports Windows 7, Windows 8.x, and Windows 10 both 32-bit and 64-bit. It requires 1.6 MHz or faster processor, 1 GB RAM, 1.8 GB free space, and Windows Installer 4.5 or newer.
You can install the latest Windows Installer by updating your operating system to the latest Service Pack. For Windows XP, download Windows XP Service Pack 3. This is the latest and last Service Pack update for Microsoft Windows XP. For Windows Vista, download Windows Vista Service Pack 2. This is the latest and last Service Pack update for Microsoft Windows Vista.
For Windows 7, download Windows 7 Service Pack 1. This is the latest and only Service Pack update for Microsoft Windows 7. For Windows 8, you should update to Windows 8.1 from the Windows Store.
