Missing ORUN32.exe on Norton WinDoctor
I am running WinDoctor and there is an error that says “ORUN32.exe is missing” and so I cannot access learn32.dll and pctree32.dll. What should I do?
I have two possible solutions for your problem.
1. Have a registry cleaner and fixer if you have a program that you trust please use it but I will give you also a link on the software I am using link: http://www.piriform.com/ccleaner. Use this program to clean and fix your registry, then try opening WinDoctor again but if this solution does not fix your problem
2. Let us try another fix it will be uninstalling the whole windoctor and then try installing it again, the file might be already corrupted so we need to install again. ( I want to give you a link to have the file orun32.exe but I can’t find a good source)
You possibly need to reinstall it , please remove all files and if its installed then go to start -> control panel -> click on programs and features (win 7 ) or click on add or remove programs (win XP) now uninstall the respective program .
Now download edit again , make sure its the latest in order to fix any known bugs . Now install it , hope that it will install .
If still you cant install means clear your temp directory first .
Click on start and then run , for shortcut press win key + r then delete all the files inside it ,don't worry it wont harm your PC , now ignore any undeletable files . Now visit this URL and http://www.how-to-fix-errors.com/errors/fix-orun32.exe-error-orun32.exe-error-fix.html
Hope that helps solve your issues .
Thank you Brionas brain and Lesten Pasio. I did what you said and reinstalled the application. Also cleared the temp. The link given by Lesten is also very helpful. Many thanks! TechyV continues in helping me with my problems .
Notifications
