Here is something for you to solve: I used Microsoft Front Page 2003 to create my website.
However, several page titles were created in WordArt.
I don’t have problems running it in Internet Explorer. But it is disappearing when running it in either Firefox or Safari. How does it happen?
What do I need to do to fix it?
I understand if the issue is not in your area of interest, if so perhaps you could pass it on to your counterpart at Front Page.
Many thanks.
lee hung
75 points
Missing Page Titles when running on specific browser
Hello Daryl,
When creating the website, did you set it in a way that it could be used in all the browsers or you set to be used in internet explorer only. I am not sure about front page but there is an option like that in Dreamweaver, so I strongly suspect that there should be one in front page too.
Check the code to ensure that you have used plugins that will allow the website to run on all browsers without bringing compatibility issues.
Test your website with several browsers to see if the display is all right. Otherwise you can get some applications for creating menus like SWISHMAX which will help you create menus that are compatible to all the browsers.
Regards
Lee Hung
