Missing Task Manager Tray in Windows 7
Hi to everyone,
A problem with Windows 7 task manager tray. I cannot seem to find the windows 7 task manager tray; I have to find the short cut of updates, battery status, volume and wireless internet connection short cut. I am not comfortable if the windows 7 tray is not present in my Windows desktop. Please do give some way to fix this.
 Your suggestion is very much welcome.
Answered By 0 points N/A #174595
Hi Melissa,
                 Good question though, possibly your taskbar might be locked so all you got to do is Right click on your Desktop and Select Personalisation and in that click on Taskbar and Start Menu, there you'll get options of Task Bar, just select Taskbar location on screen to bottom and then check, also uncheck on Lock Taskbar menu and you'll get the Taskbar at the bottom of your screen. You can also Go to Control Panel, Appearance and Pesronalisation tab and do it.
Cheers!
