Hey there,
Can somebody help me, on how to get my wireless network working?
My wireless utility application got corrupted, so I uninstalled it. I later found out that I misplaced my wireless card CD, so I could not reinstall the utility.
I know Windows has its own utility but I could not find it on network connections. I know the wireless card works, since its blinking from time to time.
I'm using Windows XP Home Edition SP3.
How to find Windows Utility as wireless utility application got corrupted
Seems like the computer has not restarted, did it? And any chance that the wireless driver has been checked, if properly installed?
Yes, the computer has been restarted and the wireless driver is properly installed.
Going to services.msc and starting, Wireless Zero Configuration worked.
Thanks a lot!
I'm adding a screenshot for the benefit of all. This is what services.msc looks like and where Wireless Zero Configuration is located.
Thanks for the screenshot.
