peter swank
20 points
Posted on - 09/26/2012
I updated my iPad 2 to the latest iOS 6. I thought that everything will be fixed and there are also added features. But just this morning, I noticed that the YouTube icon is missing. I can't find it anywhere. Can someone please tell me if Apple already pulls out their support for YouTube? Or how can I bring it back? I tried searching on the App store but I can't find it.
Help needed.
Missing YouTube after updating iPad 2 to iOS 6
Apple landed ios 6 for iPhone, but this time without the pre-installed feature/app for YouTube (as previous ios have). But luckily, You Tube app is now available within the iTunes for you. You can get this app from this link:
Hopefully, you will be delighted after using this app with new features of ios 6.
For some reason, Apple decided not to include YouTube on IOS 6 update. In order to bring it back, you have to install it again from the App Store. Tap the App Store.
Type YouTube on the search box. Tap it when you found it.
Click Install to install it on your Apple device and wait till it finish the installation process. Once done you can see it on your Apple device desktop screen. You can also open YouTube through your browser. Open Safari and then type www.youtube.com and press Go.
