MiWi pro test interface error while flashing
We are getting the following error while trying to flash our code on this.
Can somebody please help us with this.
Target Device ID (00000000) does not match Expected Device ID(00005690).
I think the only problem here is that the Device ID of the attached device doesn’t match the Device ID that the program was expecting. If this is the first time that this happens, try restarting your computer then try it again.
See if there is a change after a reboot of the system. Disconnect the device from your computer before restarting the system.
If it still doesn’t work, maybe there is a problem with your program. Try doing a clean installation of the program to fix any corrupted files that may have developed from the time it was first installed.
Uninstall the application then restart your machine. After booting, check your computer for any possible errors. Use a disk utility application to check the system.
For a much thorough diagnostics test on your machine, use disk utility applications like Norton Utilities, or PC Tools Performance Toolkit. Install the program back then see if this fixes the problem.
