MMS Problems on Samsung Galaxy Phone
I cannot receive MMS or text messages with pictures on my Samsung Galaxy Ace Duos S6802. I’ve asked my operator but I did not get what they’re trying to say. How can I fix this?
You need to set up your Samsung Galaxy Ace Duos GT-S6802 for Internet and MMS. For Internet and MMS settings you can try a software as like ‘Tweakker’ .
At first connect to WiFi network then download and install ‘tweakker’ . After install follow the Three easy steps in Tweakker :
1.      Select your operator or provider
2.      Select your subscription or plan
3.      Tweakker sets up Internet and MMS Apn
For your help I include three links of this software, you can download from here :
https://play.google.com/store/apps/details?id=com.tweakker
https://play.google.com/store/apps/details?id=com.tweakker&hl=en
I thinks this above information should fix your problem. You can try it.
