I have a Samsung Galaxy S4 which won't send an MMS when I am connected to WiFi, I have tried sending without the connection and MMS sending was successful, I have a brother with Asus Nexus 7 and it sends MMS well when connected to WiFi, what could be the problem with my phone? How do I get to send MMS when connected to WiFi?
Sometimes the phone is using the cellular data and WiFi both at the same time, generally the phone switch automatically to the WiFi when you are connected to the WiFi, But due to certain issues, the phone shows both at the same time in the the status bar of your phone.
In this case Please switch off your cellular data when connected to WiFi,and then try to send MMS, it must work fine.
If you want to send a media like an MMS to someone, try to turn off your phone’s data connection when using Wi-Fi and likewise when you are using your phone’s data connection, turn off your phone’s Wi-Fi. The Samsung Galaxy S4 I9500 is a 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies.
It was announced to the public on March 2013 and released on April 2013 measuring 136.6 x 69.8 x 7.9 millimeters and weighing 130 grams. It is built with plastic body and uses micro-SIM card. It has Super AMOLED capacitive touchscreen display with 16M colors at 1080 x 1920 pixels screen resolution protected with Corning Gorilla Glass 3.
Samsung Galaxy S4
It ships with Android 4.2.2 Jelly Bean upgradable to Android 5.0.1 Lollipop with TouchWiz UI powered by 28 nm Exynos 5410 Octa chipset, Octa-Core processor (4 x 1.6 GHz Cortex-A15 and 4 x 1.2 GHz Cortex-A7), and PowerVR SGX544MP3 GPU. It supports microSD expandable up to 64 GB. It runs on 2 GB RAM with internal storage available in 16 GB, 32 GB, and 64 GB capacities.
The primary camera supports 13 megapixels featuring f/2.2, 31mm (standard), 1/3″, 1.14µm, and AF with HDR and LED flash. It can record video in 1080p at 30 fps with dual-video rec. The secondary camera supports 2 megapixels featuring f/2.4 and 31mm (standard) with dual video call. It can record video in 1080p at 30 fps.
It has 3.5-millimeter jack featuring active noise cancellation with dedicated mic; Wi-Fi 802.11 a/b/g/n/ac with dual-band, Wi-Fi Direct, DLNA, and hotspot support; Bluetooth 4.0 with A2DP, EDR, LE, and aptX support; GPS with A-GPS and GLONASS support; NFC; infrared; and microUSB 2.0 with MHL 2 TV-out and USB Host support.
It has built-in accelerometer, gyro, proximity, compass, barometer, temperature, humidity, and gesture sensors: ANT+, S-Voice natural language commands and dictation, and air gestures. It runs on removable Li-Ion 2600 mAh battery with standby time up to 370 hours on 3G and talk time up to 17 hours on 3G. It is available in White Frost, Black Mist, Arctic Blue, and Black Edition colors. It supports Qi wireless charging.
1....
