Mobile battery is not work more than 6 hour
Mobile battery is not work for not more than 6 hours in nokia 5130 mobile phone. i am also change my mobile battery
The reason why you Nokia 5130 is not lasting for more than 6 hours is probably because of the following:
Hope this helps.
Carl
The battery of a Nokia 5130 will last for 6-hours when in talk time and 21-hours when used for music. Maybe the reason why it does not last is you are using it continuously and some applications are opened at the same time. You have to close every application you open when not in use. And also, do not use your mobile phone when it is charging. Do not over charge it because it is one of the common reasons why mobile batteries get damaged.
