When I try to connect to internet i.e. GPRS to my PC by using mobile networking wizard facility available from
'Sony Ericson PC Suite'.
See the uploaded image below for the proof of the error code 720.
Mobile Networking wizard
(720) A connection to the remote computer could not be established. You might need to change the network settings for this connection.
OK
Please help me from this,
Thanks,
Mobile Networking Wizard Error Sony Ericson
The mobile networking wizard has the ability to detect the connection setting of the service provider you are connecting to once it has run. This is done by creating a new connection for every service provider. In the event, thousand does not detect the settings; you are required to manually put the appropriate details. If the settings do not correspond to those of the service provider you are connecting to, you end up getting the “error code 720"
It is advisable to call customer care for these settings. You should note that these settings correspond to the one you put on your mobile device. If GPRS connection is available on your mobile device, just copy the settings from the mobile to the PC suite.
