Mobile Phone Can Share Internet connection?
Yes, that has become possible now. But it is only possible in those cell phones which have got the option of the hotspot. The hotspot is a feature which makes your cell phone become as an access point for the other cell phones to use its internet connection. In this case the cell phone (that is acting as an access point) for the other cell phones will be charged by the cellular network which can be costly sometimes. That is why people often do not use this option much.
You can go to various websites of cell phones and check different phones whether they have got the option of Wifi-hotspot or not. A very commonly used website is https://www.gsmarena.com/.
Sharing the internet connection on your mobile handset to other mobile phones is very possible but has a great impact on your device. You can share the internet connection on your device by making it a Wi-Fi hotspot. Most versions of Smartphones nowadays support this feature. Setting your handset to be a Wi-Fi hotspot is called “tethering” which I’m sure you can find by tapping on the Settings icon of your handset.
By setting your device to be a Wi-Fi hotspot, other handsets will be able to connect to it using Wi-Fi then be able to browse the web. But like what I said earlier, transforming your mobile phone into a Wi-Fi hotspot will have a great impact on your handset. This method of sharing the internet will easily drain your phone’s battery and you should be in range with the handsets that connect to you or else they will be disconnected.
Good and very informative comments. I am interested to share internet on other mobile devices but for that I needed to make Wi-Fi hotspot feature which is not familiar to me. Your easy instruction helps me to make Wi-Fi hotspot, as a result, now I am able to share the internet connection on my mobile handset to other mobile phone. Good comments, thanks to you and Techyv as well.
