What to do when Mobile phone gets wet
Asked By 210 points N/A Posted on -
My mobile phone could get wet by one way or another. I worry as I could mistakenly drop my mobile phone in water. It can also get wet if I go out in a heavy rain. However, now I panic so much. It is possible to save my wet mobile phone by quickly repairing it.
Please give me the repairing solution.
Best Answer by salmangadi
Answered By 0 points N/A #129064
Dear HASNAT,
There is not any cure about the repairing but some tricks and tips I share with you.
  • Always cure before caution comes, like if you see a cloudy or dark weather take a shopper with you and in case of rain you can put your mobile in shopper and close it properly to avoid becoming wet.
  • If your mobile fall in water or somehow it become wet and when you see the mobile screen it is off, in that situation never ever try to start your mobile. After coming back to home open all the casing of the mobile and battery and then put in sunlight to be remain not to be wet and do not use that battery, try to purchase a new one and use the new battery.
These are specific methods by which you can save your mobile 70-80% chances that it would work.
Answered By 0 points N/A #129065
Several things you have to do to save your Mobile Phone drop in water is to act immediately. Quickly remove all the detachable parts as well as covers possible such as the back cover, battery, the SIM card, memory card etc. Then wipe it with a piece of cloth or tissue paper to wipe out the water residue you are able to see in the Mobile Phone. Make sure that you dry it completely.
Failure to do this, the water trapped inside the mobile phone will begin to evaporate and gather in places which are difficult to reach. This procedure will save your wet mobile phone and it will start working if it was under water for just a little while. After this, use a hair dryer and start drying the Mobile Phone focusing in the area where the battery is situated. Make sure that you are not holding the dryer too near the Mobile Phone, too close to the Mobile Phone will harm the electrical mechanism of the phone.
Keep drying from a safe distance for about twenty to thirty minutes. If it still does not work, try taking off the covers including the battery from the Mobile Phone and place the phone in a dry/warm place to allow the water inside the phone evaporate slowly from the little holes in the Mobile phone.
Thank you.
Answered By 0 points N/A #129067
One good way to save a phone that has fallen in the water is to immediately turn it off and try to open it and take out the battery and mop up all visible signs of water. Next follows the following steps below:
Step 1: Then you will need to get an air tight container, a plastic bag or a glass jar and fill it up with rice.
Step 2: Put the phone inside the air tight container with the rice, and store the container in an air cool place like a cupboard for example.
Step 3: Leave the phone in the container for a day at least.
The rice would help to drain out water from inside the phone. This works well for Apple iPhone and should work well also for any other phone or electronic hardware similar to a phone. If even after doing this your phone should come on. If your phone is still not coming on then you would need to take it to a phone repairer. Hope this solution helps you.
