A mobile phone on how its really works
Hello!
There are steps on how to create or build your own mobile phone. You have to have your own platform in building one. In the process of creating your mobile phone, there are tests you make in order for them to function well. There are test hardwares you use in order to see if the mobile phone is functioning completely.
Test devices that have the capabilities of testing the functionality like voice and data communications and wireless telephony should be included when you want to create a mobile phone. When you are done in creating your mobile phone, make sure you test again its functionality and see if you are satisfied with it.
Hope it helped.
-Neil-
Of course, in the construction of a mobile phone it’s not just the design and features that matters. It takes pure planning and designing on the whole circuitry of the device and this also applies to all electronic devices that are brought to the market. In a mobile handset, the part that is very important that makes it work is its board. Without it you won’t be able to use it and if it’s not designed well it will only have a very short lifespan.
The circuit layout on the board is carefuly designed by sets of engineers that are dedicated on designing the circuitry of the device making sure that all parts will work as expected. Of course, I’m sure there are times the layout seems faulty. In this case, they just need to analyze the present layout to see what went wrong and then come up with another design that will fix the problem encountered. But it’s not all “trial-and-error” thing or else they will just be throwing money on defective designs. All layouts and designs undergo careful computations.
Well, a mobile phone is a very important part of our daily activities. But few of us know something or anything about how it is created and how it works. Here everything is explained quite clearly. The circuit board’s design and its working system are explicated in an easy way that everyone will understand. Both experts posted their own opinion. I appreciate them both. But I have great remarks for Sharath Reddy. I have not seen anyone who has penetrated so clearly before. I have learned much from this post. It really helped me to make my assignment on mobile phone. Thanks Sharath Reddy for your great help and thanks to Techyv too.
