jamiescott
Posted on - 10/05/2011
My blackberry 8520 got problem sum keypads not working and some time display gone and also getting error in surfing Internet service center people saying that its a hardware damage but i facing the problem from the very first day when i bought it so can you tell me what hardware problem it is?
Mobile phone keypads not working
Dear, there is one person who also faced same problem with his blackberry mobile phone 8520 same like you i know him and he has told me how he solved his that problem. He told me because he was worried more when he had this problem that's why he want to share it to other persons to overcome their tensions.
He just changed the complete track ball module, It is sure that your mobile keypad having problem due to water damage.
That's why i would like to suggest you just change your complete track ball module of your mobile phone make your phone working properly in a right way. One another option for working of your phone for a short time in this problem you just clean its ice and rehot them, than your phone will working properly.
I suggest you must be do like this.
These situation happens to all cell phone. Keypad is not working of some of the keys are not functioning.
Spilled water on cell phone often is the cause of this issue. But this can be fix, by simply re-installing the software of your BlackBerry.
Bring this cell phone of yours to any cell phone shops that knows how to repair cell phone. They'll reformat the software installed and often it'll fix keypad issue.
Worse thing might happen is a hardware firmware failure. If this happens, this is very hard to fix and often the solution is a cell phone replacement.
