adam shaw
Posted on - 11/28/2011
I just got a Micro SD card then I uploaded some music, photos and themes into it. Afterwards, I put the SD card back to my phone and browse for the newly added files, but there is nothing on my SD card. How can I know if my memory card is corrupt or damage? How can I fix it?
lee hung
75 points
Mobile Phone unable to read Micro SD card
Hallo Adam,
To know that the memory card is corrupt, you will need to try using it on another phone that you are sure does not have problems when it comes to working with the micro SD card. Plug it in and see if you can be able to view the files. In case you cannot, then the memory card has a problem.
You may also try accessing the memory card from your computer. Just plug it in a memory card reader and then try accessing the files from the laptop, if it refuses to open and you can see it, try formatting it and see if that will solve the problem.
Hope this helps.
__
Regards
Lee Hung
