I was trying to update MobileMe Calendar, but an alert showed up stating that my events can't be automatically updated.
I clicked on the "Continue with Upgrade" button,but the process did not end successfully.
The window automatically closes.
How can I continue with the update without going to the same process?
Your events can’t be automatically upgraded.
You can still upgrade and manually import your calendars after your upgrade is complete.
If you continue with your upgrade, instructions for manually importing your calendars will be sent to your MobileMe email address.
MobileMe Can’t be Automatically Upgraded
Hi Eden,Â
This problem is actually common for first time upgrades.Â
The reason for the failed upgrade maybe because the MobileMe Calendar server is logged due to a lot of online users that are also having their upgrade. Do try to upgrade the program hours after your last attempt to upgrade. That way, you may succeed with your upgrade.
Another reason why you received that kind of message is that, you may have exceeded with the maximum entries that the MobileMe calendar allows. If the sum of your calendar exceeds 400, then consider omitting some of it.
If the same issue still occur after you have followed the advices on the above mentioned. Try resetting the sync on your MobileMe calendar. Wait for a couple of minutes before hitting the upgrade button again.
