Mobtkr Application Error Windows XP
Hey experts,
I hope you can help me with my problem, about mobtkr speeder.
I downloaded Mobtkr Speeder, on my Windows XP computer. When I tried to run the program. This error message immediately appeared.
Mobtkr Speeder v 3.2.exe – Application Error
The application failed to initialize properly (0xc0000135). Click on OK to terminate the application.
Even after I clicked close or “ok” the same error message still appeared. After a few minutes I also noticed that my system began to slow and frequently hang up. I tried to reboot my computer, but this error message keeps showing up again.
I tried to uninstall the program, and reinstall it but it did not fix the problem. What should I do to run this program successfully?
Can someone help me ?
Thanks in advance.
