Mod hover track issue on my pc
I have a mod hover track problem on my pc. Whenever I hover on a track, on a link, the status bar does not show where it would go to anymore. Is it a problem with my settings?
Hello Dudley,
Try the System Restore feature in your operating system and see if that could rectifies the issue.
If it's still there. That could be a virus running in your system. Try running your favorite antivirus to solve the problem you are having. If your anti virus fails to detect the problem and you are sure it's updated. Try repairing your OS with your OS disk installer. If all else fails then I suggest you to back up your computer and then thoroughly reformat your computer to solve the problem. This is the last step and should free you from the troubles you are having.
Hope this helps you rectify the issue you have.
