Model Saving Error on Navicat
I am getting the following error message with Navicat and shows “Model Saving Error: model index field error”. It is very annoying to me. Please suggest me to fix this issue ASAP. I would be grateful to you. Thanks in advance.
Model Saving Error: model index field error.
Best Answer by Vega Wilken
Answered By 0 points N/A #189889
This is a software problem and you can resolve it very easy and very fast. The problem is that Navicat doesn`t refresh the view. You only have to click on refresh and regenerate the ER Diagram and then you won`t have any problem and you will can use the program with no errors.
Answered By 0 points N/A #189890
Hi Alisha
There is an easy way to resolve the problem experiencing with “error Message: Model Saving Error: model index field error” at NAVICAT. Actual view doesn’t refresh the view, GUI has to fix it. The way of fixing this error is just click on refresh. Find below the ER diagram and click on refreshing
Hope this will help for fixing your problem
