Hi I-Guru,
Models for iPhone 5C are
1) A1532: iPhone 5C (GSM Model)
2) A1456: iPhone 5C (CDMA Model)
3) A1532: iPhone 5C (CDMA Model)
4) A1507: iPhone 5C (GSM Model)
5) A1526: iPhone 5C (GSM China Model)
6) A1529: iPhone 5C
Models for iPhone 5S are
1) A1533: iPhone 5S (GSM Model)
2) A1533: iPhone 5S (CDMA Model)
3) A1453: iPhone 5S (GSM Model)
4) A1457: iPhone 5S (GSM China Model)
5) A1530: iPhone 5S
The storage capacities for iPhone 5C are 16 GB and 32 GB, for iPhone 5S are 16 GB, 32 GB, 64 GB.
Face time is free from iPhone to iPhone.
Steps to disable fingerprint scanner in iPhone 5S are:
1) Set the user id and password to unlock the screen of iPhone 5S
2) Make the Airplane Mode inaccessible from the lock screen
3) Add PIN after setting the Airplane to access the screen
Here are 7 major differences between iPhone 5C and iPhone 5S, here are a link for more details:
1. Processor Speed = iPhone 5S has a faster processor than iPhone 5C's. IPhone 5S has 64-bit processor compared to iPhone 5C that has only 32-bit processor.
2. Motion Co-processor = iPhone 5S has motion Co-processor but iPhone 5C doesn't.
3. Fingerprint Scanner = available only in iPhone 5S.
4. Camera = iPhone 5S has dual flash, burst mode and ability to record slow motion video in 720HD while iPhone 5C does not have.
5. Colors = iPhone 5C has more attractive colour compared to iPhone 5S.
6. Storage Capacity = iPhone 5S has maximum 64 GB of storage compared to iPhone 5C that has maximum storage of 32 GB.
7. Price = iPhone is more expensive compared to iPhone 5C.
The Apple iPhone 5s is a 4G Smartphone operating on 2G, 3G, and 4G network bands using GSM, CDMA, HSPA, EVDO, and LTE technologies. It was unveiled to the public and released on September 2013 measuring 123.8 x 58.6 x 7.6 millimeters and weighing 112 grams.
Apple iPhone 5s
It uses nano-SIM card and has LED-backlit IPS LCD capacitive touchscreen display with 16M colors at 640 x 1136 pixels screen resolution. It supports multi-touch protected with Corning Gorilla Glass with oleophobic coating. It runs on iOS 7 upgradable to iOS 10.1 powered by Apple A7 chipset, 1.3 GHz Dual-Core Cyclone (ARM v8-based) processor, and PowerVR G6430 (quad-core graphics) GPU.
It doesn’t support microSD. It runs on 1 GB DDR3 RAM with internal storage available in 16 GB, 32 GB, and 64 GB capacities. The primary camera supports 8 megapixels with f/2.2 and 29mm featuring dual LED flash (dual tone), autofocus, geo-tagging, 1/3″ sensor size, 1.5 µm pixel size, touch focus, face and smile detection, and HDR (photo/panorama).
It supports 1080p video recording at 30 fps and 720p at 120 fps. The secondary camera supports 1.2 megapixels with f/2.4 and 31mm and 720p video recording at 30 fps with face detection, HDR, and FaceTime over Wi-Fi or Cellular.
It has 3.5-millimeter jack featuring 16-bit/44.1kHz audio and active noise cancellation with dedicated mic, Wi-Fi 802.11 a/b/g/n with dual-band and hotspot support, Bluetooth 4.0 with A2DP support, GPS with A-GPS and GLONASS support, and USB 2.0 reversible connector. It doesn’t have FM radio. It has built-in fingerprint, proximity, compass, accelerometer, and gyro sensors. The pre-installed Safari web browser supports HTML5.
Java is not supported. It runs on non-removable 5.92 Wh Li-Po 1560 mAh battery with standby time up to 250 hours both on 2G and 3G. Talk time is up to 10 hours both on 2G and 3G. It is available in space gray, gold, and white/silver colors.
The Apple iPhone 5c is a 4G Smartphone operating on 2G, 3G, and 4G network bands using GSM, CDMA, HSPA, and LTE technologies. It was announced to the public and released on September 2013 measuring 124.4 x 59.2 x 9 millimeters and weighing 132 grams. It is built with plastic body and glass front and uses nano-SIM card.
Apple iPhone 5c
It has LED-backlit IPS LCD capacitive touchscreen display with 16M colors at 640 x 1136 pixels screen resolution. It supports multi-touch. It runs on iOS 7 upgradable to iOS 10.3.3 powered by Apple A6 (32 nm) chipset, 1.3 GHz Dual-Core Swift (ARM v7-based) processor, and PowerVR SGX 543MP3 (triple-core graphics) GPU. It doesn’t support microSD.
It run on 1 GB RAM with internal storage available in 8 GB, 16 GB, and 32 GB capacities. The primary camera supports 8 megapixels with f/2.4, 33mm (standard), 1/3.2″, 1.4µm, and AF featuring LED flash, panorama, and HDR. It supports 1080p video recording at 30 fps. The secondary camera supports 1.2 megapixels featuring face detection and FaceTime over Wi-Fi or Cellular.
It supports 720p video recording at 30 fps. It has 3.5-millimeter jack featuring 16-bit/44.1kHz audio and active noise cancellation with dedicated mic, Wi-Fi 802.11 b/g/n with hotspot support, Bluetooth 4.0 with A2DP and LE support, GPS with A-GPS and GLONASS support, and USB 2.0 proprietary reversible connector. It doesn’t have FM radio. It has built-in accelerometer, gyro, proximity, and compass sensors.
The pre-installed Safari web browser supports HTML5. It runs on non-removable 5.73 Wh Li-Po 1510 mAh battery with standby time up to 250 hours both on 2G and 3G. Talk time is up to 10 hours on 3G. It is available in white, blue, green, yellow, and pink colors.
1....
