I am trying to load Moder Combat game on HTC explorer but it won't load. Whenever I launch the game it keeps showing "apkmania.com loading". The version of Moder Combat is 3 v1.1.3 is the latest as it won't download any further updates. I have checked my internet connection and it is working fine. The only problem is when launching the Moder Combat. Is there anyone with a similar problem? How can it be fixed? I appreciate any kind of help.
Moder Combat 3 v1.1.3 Won’t Load on HTC Explorer
Android apps, in many case, makes good problem with loading. Try the followings.
Most possibly, the installation of your game is corrupted and might be cracked. Using cracked apps are strongly NOT RECOMMENDED, they will crash and even might exploit malware.
First of all, uninstall the game from your phone.
1. Go to Apps >> Settings.
2. Tap “Application Manager”.
3. Tap on the game >> tap “Uninstall”.
After you’ve successfully uninstalled, download it from Google Play. Google Play is the safest place to get the pure apps without any problem. Get Modern Combat 5.
In some case, your device might be the culprit. Installing OTA updates are recommended, as they fix many issues and increase the performance.
2. Tap “About device” from bottom.
3. Tap Software update >> Update.
Now, your game should run smoothly.
