Module FeatureCompatLate Power on Failed
I can't seem to make the masking tests work to be able to check on the CPU checking code so not to use the whole test equipment when needed. I tried masking vendor but when I tried to run on the Workstation 9 and Fushion 5, an error always appear and I'm not sure how to fix it. The error is enclosed below. I tried masking from Intel to AMD.
Cpuid – VMware Workstation
Feature 'cpuid.AMD' was absent, but must be present.
Module FeatureCompatLate power on failed.
Failed to start the virtual machine.
OK
