Why is mondoDb server start crashing after I upgrade it from 2.2. i have noticed recently that mongoDb ser on Linux Ubuntu started crashing after I upgrade Mongodb 2.2 to 2.6.6 the latest version. The old version was working fine before the upgrade. What could be the cause of the behavior?
Mongodb start crashing after upgrade.
Hello Paul!
MongoDB 2.6.7-rc0 is out and it contains all the fixes since the 2.6.6 version. I recommend you to upgrade to this version. You can download it HERE and check the list of all the issues on this link
The next expected stable release for upgrading will be 2.6.7.
Regarding the cause of the crashes after you upgraded from 2.2 to 2.6.6 is most likely the CPU memory limit.
Regards, Mathew
