anonymous
7060 points
Posted on - 08/05/2011
I have been facing a problem for many days. That is when I switch on my CPU and Monitor then computer runs but the main problem is nothing is visible on the monitor . About an hour later monitor light comes up . How can I solve this problem.
Monitor light is not comes up
Well, there are huge chances that it is the fault of hardware not of software. It is causing due to your data cable error which connects your CPU and monitor or there is a fault in your monitor. In monitors there are a lot of defaults occur n its picture tube or its fly back. You should consult to a specialist of hardware especially of monitors. If there is a fault with the picture tube of your monitor then i suggest you that replace your monitor with a new one because the rate of the new picture is comparatively equal to a new monitor so it is better to replace it with a new one.
