Edward Rand
40 points
Posted on - 04/30/2013
I have already created a program to wake up from sleep mode using Delphi 7 much like that of Windows Task Scheduler. My only problem with computer wake Windows Delphi is, it won't turn the monitor on? Can someone help me out here? I'm on Windows 7 64 bit. Thanks in advance.
Monitor won’t turn on in computer wake Windows Delphi 7
It would be much better if you just download the latest WakeupOnStandBy application. It could be that the root cause of your problem is due to the Operation System that you are using. Once the program is activated, it automatically set your computer to wake mode in accordance to your programmed time, meaning your monitor is also turned on.
Hi Edward,
 This might also coincide with other factors in the computer. Remember that there was a widespread issue with Windows 7 32 or 64 bit in putting it into sleep and making sure that it wakes up so as the monitor say, when you move your mouse. You might want to check if updates are made for your Video Driver or BIOS.
