The monkey extract for windows
I'm having trouble for a visual effect edited on Avid. Can I render only a sequence and not the entire film on DPx. Does someone know how to use the monkey extract for windows?
Hello
The monkey extract software that you want to use for windows is good enough for kind of work you doing. It has many features such as edit, split, search; replace; rename; alter list trim truncate,.It has other features as well set attributes, encypt, decrypt, wipe, delete, extract and more. It has a nice interface that allows you to work smoothly. However there are downside as well,Its quite prone spyware and all. However you must look for updated version. Sending you link and picture, which will be very useful for you.
http://download.cnet.com/s/the-extractor/
Thanks
