athan haas
20 points
Posted on - 06/01/2012
Latest researching application upgrade by Bing which give an easy way to search through web by enabling experts and web enthusiast to accompany you to do more, is this preferable than Google docs?
More Comfortable Searching Offered By The Latest Bing
The number of users sharing one WIFI connection is inversely proportional to the performance of the network. The usual claim of most wireless points or routers on the number of devices one connection can support is 255. However, connecting 255 devices simultaneously is not recommended because it will result to poor performance. If you are aiming for a larger area of coverage, installing multiple access points is recommended. The performance of the connection also depends on the bandwidth of the devices and what the devices are doing. For optimal performance, it’s best to test the number of devices a given connection can handle simultaneously without slowing the down.
