More info about Aio PC
Recently there are news everywhere about AIO pc. I want to know what is an AIO PC ? What is the difference between a normal PC and an AIO PC ?
Hi there,
AIO PCs are just compacted in one single box. Everything in this PC is just like normal PCs. But you cannot carry a normal PC with you all the time but this all in one pcs are really easy to carry and also its performance is great like desktop PC. All these PCs have very high resolution display, powerful graphics support and enough RAM to work efficiently. The storage is around 1TB for all the PCs. Supports wired and wireless internet connections, optical drivers are blu-ray/dual-layer DVD burner. Supports windows 8 pro (64bit)
Thank you,
Riley weaver.
AIO or AiO is the short term that stands for “All-in-One”. It is a desktop computer or a type of desktop computer where all components are within the same case as the monitor except for the mouse and keyboard, that is. When LCD monitors were first introduced, AIO PCs have become slimmer, smaller, and much cheaper.
An AIO PC consumes less power and generates lesser heat aside from being visually attractive, compact, and easy to setup compared to a regular desktop computer. There are several types of AIO PCs that support multi-touch display features. It has a user-friendly design and you can easily connect peripherals and accessories.
Ports are located at convenient positions for users which are usually below or on the side of the monitor. One of the major advantages of using an AIO PC is that it saves space because the monitor is built-in to the system. The technology applied in an AIO PC is the same as when manufacturing laptops. This also in some way brings in another benefit: the reduction of cables.
In an AIO PC, you don’t require a separate power cord or video cable for the monitor. Besides all of the many benefits, there are specific disadvantages to using an AIO PC. One of the major disadvantages is upgradability. In an AIO PC, upgradability is normally limited to RAM. Tweaking, customizing, or repairing can be difficult in an AIO PC.
When a single component fails, it often leads to the replacement or repair of the entire unit. An AIO PC has a much lower processing speed and graphics capabilities unlike a regular desktop computer plus the fact that it is more expensive compared to a regular computer.
Hi
All-in-one PCs, also known as all-in-one desktops, integrate the computer case and system components into the monitor so that the entire PC is contained all in one unit. For more info visit this Techyv article :
Notifications
