More info about new Silverstone Cases
Silverstone has brought new cases with great design . I need to buy a case ASAP. But I am worried about the airflow ? Does they have good airflow ?
Hi Richard
When it comes to computer chassis, the brand that will ring a bell is Silverstone. Silverstone dedicates their work mainly on the airflow. With their great designs you can really tell that it’s a masterpiece. Silverstone released a new design called Raven 4 and the FT04 that will only differ on the materials used.
The Silverstone Raven 4 is a plastic case with a “Hi –Flow air Filter” that will maximize the airflow. It has removed the rear grill to achieve a better airflow. The FT04 of Silverstone has the same design and structure as the Raven 4 but the material used is aluminum.
I would highly recommend Silverstone.
Hope you will find this helpful.
Cheers
