Hello, I’m looking for more webcam recorder software. What software would provide better quality video for video chat? Also, along with software, do I need more webcam recorder bandwidth to store better quality videos?
More webcam recorder software for better quality
Hello
After some research I found this application, on CNet users rated it with 4 stars (which is good) so I think this application will be good for you. This application is compact and straightforward. It has nice graphical interface and it's easy to use.
You can find it on this link: https://www.techyv.com/questions/there-any-voice-call-messenger-blackberry-9900-model/, and you can find more information as well.
This is how it looks like:
I hope I helped you. Regards.
Hi Robinson,
Here is one of the best webcam video capturing software that you can get for free. Its called CamStudio.
The software is free and it allows you to capture webcam videos in High Quality including the audio part.
One of the key features of this software is the ability to convert the videos you record to SWF file format which can be uploaded right away to Video streaming sites.
